ivanr
- Slough, United Kingdom
- Engineer
Hope this is the right forum for this.
I have a small control box housing a PLC and HMI.
Upstream of the PLC is the disconnect/isolator switch followed by UL489 MCB, followed by Control Isolating transformer, secondary feeding PLC and control circuit.
Would I be right in saying that I can use a UL508 Disconnect/Isolator (non-fused) instead of a UL98 disconnect which seems overkill as there are no power circuits in the control panel. Any thing else I should know.
FLA of the panel is only 2 Amps.
