Product Safety Guy
- Columbus, Ohio, USA
I have noticed that there is an NRTL that requires notation on the control drawing that directs the user/installer to use only <insert same-NTRL name here> approved associated apparatus that is compatible with its entity parameters.
I know this problem can be solved in a number of different ways, but that's not what I am looking for here.
So my question to the AHJ's out there is this: If you see an installation of an IS apparatus approved by NRTL1 connected to an Associated IS apparatus approved by NRTL2, the entity parameters line up properly, but the control drawing for the IS apparatus specifies an NRTL1 approval of the associated IS apparatus, do you reject the installation or approve the installation based upon the accreditation of both NRTL1 and NRTL2, proper markings, and compatibility of the entity parameters?
Thanks!
Thanks!
