A customer wants wireless control of the lighting at his new pool house I'm going to use the Lutron Casseita to facilitate this for ease of use programing. I am going to have 100% hidden 24 volt Led tape strips i use a sirs-E acuvivid 95+cri CC 24V the amount of load on the different zones of tape will exceed most line voltage dimable led drivers. Therefore I am trying to control on off of drivers or DC supply. I have found a interface for 120v dimmer to 0-10v signal or PWM.. here are my drawings to illustrate what I was thinking originaly... i think i changed the desing a little below
after a little further studying i would actually
like to use 2 of the MW HLG-600H -b XMFR and use the remote controll ( rc+ & rc- directly shorted triggers standby) for switching of the DC output side and to avoid inrush currents and use multiple seperate DT-AN10 controlers for the dimming function and seperating strip zones by dimmer.
1 dedicated curcuit for the casetta dimmer devices only a Current switch adjustable (NO) over the neutral or power on the home run....to apply 120v to a IDEC SPDT that opens the NC contacts for RC+ & RC- taking the driver out of stand by then the DC out feeds through the DT-AN10 using the PWM dimming function... i think this might work but i will need 2 600W supplies so i will have to actualy have 2 CT switches and 2 idecs to take either driver out of stand by mode..
i will try and get my revision drawing up soon any help is appreciated
Casetta dimmers
https://www.google.com/url?sa=t&rct...ructions.pdf&usg=AOvVaw3ns3oNJtRiucff7zXQoRU8
current sensor..... https://www.alliedelec.com/m/d/671749b2426ee62a1eebdbe15fe7a8ea.pdf
xmfr..... https://www.meanwell.com/Upload/PDF/HLG-600H/HLG-600H-SPEC.PDF
converter pwm dimmer..... http://www.digitallighting.com/animationfolder/specs/manuals/DT-AN10-PWM.pdf
Casetta dimmers
