unclestoolie
Does anyone have experience controlling a light fixture from 2 sources, both a switch and also a timeclock. The theory is to use the manual switch during the week, and then have the timeclock control a few lighting circuits on the family's sabbath, 2 days a week. If the same circuit feeds both the timeclock and switches, and I run an additional conductor in between the switch and timeclock's load side, this should work in theory, right? The switch will be totally manual, and no matter what position the switch is in when the timeclock, which is parallel to the switch, takes over, the fixture should be controlled by the timeclock Any obvious code violations?
