I work as a Technician for a large company. We have a large manufacturing building nearing completion. The building contains about 7 Motor Control Centers and 20 or more lighting and power panels. My concern is none of the equipment is marked as to where it is feed from, (panel & breaker or motor control center & bucket). It is not marked on the equipment control panels. There is no identification on the 120, 240 or 480 wiring feeding power to the control panels. There are naming differences on the physical equipment markings and what is on the wiring drawings.
The general contractor and electrical sub-contractor involved has clearly stated there is no code requirement other than to label at the power source, (motor control center or power panel) and no identification of the power feed wires is required.
From a safety aspect, there is no way to identify the power source feeding a control panel or piece of equipment except for wiring drawings which will be kept in another building. This assumes that the electricians and apprentices installed everything by the prints and knew what each piece of equipment was. To date, equipment has been damaged when an electrician hooked up 480/3 phase to a 120 control panel by mistake. The control panel was clearly labeled as to voltage requirements.
Is there any help in the codes for requiring power source identification at control panels or equipment?
Thank you!
Thank you!
