You may find that having a copy of NFPA79, Electrical Standard for Industrial Machinery may be a good resource.
It appears as though there are many that are not familiar with this document this is the table of contence for it:
http://www.nfpa.org/aboutthecodes/AboutTheCodes.asp?DocNum=79#
NFPA? 79 Electrical Standard for Industrial Machinery 2012 Edition
Chapter 1 Administration
1.1 Scope
1.2 Purpose
1.3 Application
1.4 Specific Provisions Other Than NFPA 79
1.5 Specific Provisions Not Made in Relation to NFPA 70
1.6 State of the Art
Chapter 2 Referenced Publications
2.1 General
2.2 NFPA Publications
2.3 Other Publications
2.4 References for Extracts in Mandatory Sections
Chapter 3 Definitions
3.1 General
3.2 NFPA Official Definitions
3.3 General Definitions
Chapter 4 General Operating Conditions
4.1 General Considerations
4.2 Electrical Components and Devices
4.3 Electrical Supply
4.4 Physical Environment and Operating Conditions
4.5 Transportation and Storage
4.6 Provisions for Handling
4.7 Installation and Operating Conditions
4.8 Available Fault Current
Chapter 5 Incoming Supply Circuit Conductor Terminations and Devices for Disconnecting and Removing Power
5.1 Incoming Supply Circuit Conductor Terminations
5.2 Grounding Terminal
5.3 Supply Circuit Disconnecting (Isolating) Means
5.4 Means for Removal of Power for Prevention of Unexpected Start-Up
5.5 Devices for Disconnecting (Isolating) Electrical Equipment
Chapter 6 Protection from Electrical Hazards
6.1 General
6.2 Protection Against Direct Contact
6.3 Protection Against Electric Shock from Indirect Contact (Fault Conditions)
6.4 Protection by the Use of Protective Extra Low Voltage (PELV)
6.5 Protection Against Residual Voltages
6.6 Protection Against Arc Flash
Chapter 7 Protection of Equipment
7.1 General
7.2 Overcurrent Protection
7.3 Overload Protection of Motors
7.4 Abnormal Temperature Protection
7.5 Protection Against Supply Interruption or Voltage Reduction and Subsequent Restoration
7.6 Overspeed Protection
7.7 Phase Sequence Protection
7.8 Protection Against Overvoltages Due to Lightning and Switching Surges
7.9 Power Factor Correction Capacitors
Chapter 8 Grounding
8.1 General
8.2 Equipment Grounding (Protective Bonding) Circuit
8.3 Control Circuits
8.4 Lighting Circuits
Chapter 9 Control Circuits and Control Functions
9.1 Control Circuits
9.2 Control Functions
9.3 Protective Interlocks
9.4 Control Functions in the Event of Failure
Chapter 10 Operator Interface and Control Devices
10.1 General
10.2 Pushbutton Actuators and Color Graphic Interface Devices
10.3 Indicator Lights and Icons of Color Graphic Interface Devices
10.4 Illuminated Pushbuttons
10.5 Rotary Control Devices
10.6 Start Devices
10.7 Devices for Stop and Emergency Stop
10.8 Devices for Emergency Switching Off
10.9 Displays
Chapter 11 Control Equipment: Location, Mounting, and Enclosures
11.1 General Requirements
11.2 Location and Mounting
11.3 Degrees of Protection
11.4 Enclosures, Doors, and Openings
11.5 Spaces Around Control Cabinets and Compartments
Chapter 12 Conductors, Cables, and Flexible Cords
12.1 General Requirements
12.2 Conductors
12.3 Insulation
12.4 Wire Markings
12.5 Conductor Ampacity
12.6 Conductor Sizing
12.7 Conductors and Cables Used for Flexing Applications
12.8 Cords
12.9 Special Cables and Conductors.
Chapter 13 Wiring Practices
13.1 Connections and Routing
13.2 Identification of Conductors
13.3 Wiring Inside Enclosures
13.4 Wiring Outside Enclosures
13.5 Raceways (Ducts), Support Systems (Cable Supports), Connection Boxes, and Other Boxes
Chapter 14 Electric Motors and Associated Equipment
14.1 General Requirements
14.2 Reserved
14.3 Motor Dimensions
14.4 Motor Mounting and Compartments
14.5 Criteria for Selection
14.6 Protective Devices for Mechanical Brakes
14.7 Direction Arrow
14.8 Marking on Motors
Chapter 15 Accessories and Lighting
15.1 Accessories
15.2 Local Lighting of the Machine and Equipment
Chapter 16 Marking and Safety Signs
16.1 General
16.2 Safety Signs for Electrical Enclosures
16.3 Function Identification
16.4 Machine Nameplate Data
16.5 Equipment Marking and Identification
Chapter 17 Technical Documentation
17.1 General
17.2 Information to Be Provided
17.3 Requirements Applicable to All Documentation
17.4 Basic Information
17.5 Installation Diagram
17.6 Block (System) Diagrams and Function Diagrams
17.7 Circuit Diagrams
17.8 Operating Manual
17.9 Maintenance Manual
17.10 Parts List
Chapter 18 Testing and Verification
18.1 General
18.2 Continuity of the Equipment Grounding (Protective Bonding) Circuit
18.3 Insulation Resistance Tests
18.4 Voltage Tests
18.5 Protection Against Residual Voltages
18.6 Functional Tests
18.7 Retesting
Chapter 19 Servo Drives and Motors
19.1 Overload Protection for Servo Motors
19.2 Motor Overtemperature Protection
19.3 Servo Drive System Conductors.
19.4 Contactor
19.5 Cable Shield
Annex A Explanatory Material
Annex B Inquiry Form for the Electrical Equipment of Machines
Annex C Examples of Industrial Machines Covered by NFPA 79
Annex D Technical Documentation
Annex E Device and Component Designations
Annex F Electrical Enclosure Ratings: Type-Rating Versus IP-Rating
Annex G Kilowatt Outputs with Horsepower Equivalents
Annex H Minimizing the Probability of Control Function Failure
Annex I AWG Conductor Cross-Reference Table.
Annex J Informational References
Index
