francis.key19
- frederick, md
Hello,
I am struggling with an issue and hoping you can help clarify for me. I have a control panel mounted on a machine frame (grounded) at about 5' (from top of the panel to ground). The panel is 18" deep, and has more than 30" on each side clearance. Opposite from this panel is an aisleway (ie. not a wall). The panel is 24" in height. In front of this panel near ground level, the electrician ran a couple of conduits 22" from the machine frame ( meaning that these conduits is below the panel on the ground). My question is does this violate the 3' clearance rule regarding depth since 22" is within the 36" depth clearance not directly in front of the panel but below it.
If it is a violation, what options do we have because we will not be able to reroute these conduits.
Thank you in advance.
Francis.
Francis.
