mshields
- Boston, MA
I'm supporting a system that has a constantly energized solenoid valve (controls Liquid CO2). The circuit is fail safe.
They've asked that we add a relay such that a BMS will get a signal in the event of one of the EPO's (N.C.) opens the circuit and or a power failure. My concern is that in order to do this, unless they can find a solenoid with aux contacts, I'll need to put in a relay that is also constantly energized. I believe having a relay constantly energized like this is to be avoided; that the coil will burn out.
a) do they make relays suitable for constant energization and/or b) is there a better way to do this?
Thanks
Thanks
