Hello all!
I am hoping you guys can help me with a quick question I have. I need to build a very small control cabinet consisting of a few ice cube relays and some remotely mounted illuminated buttons. I would like to treat the wiring between the cabinet and the buttons as a class 2 circuit. In the past when building something similar, I would always find a transformer that is listed and labeled as being class 2. In this case, I was wondering if I could use a "control transformer", such as the one I have linked, and by using appropriately sized primary and secondary fuses, treat the secondary as class 2. My hunch says (based on the poorly written section 725 of the NEC) anything connected to this transformer would need to be class 1 and use standard chapter 3 wiring methods, but I thought I would check anyway. Thanks!
Jacob
http://www.automationdirect.com/adc/Shopping/Catalog/Power_Products_%28Electrical%29/Power_Transformers/Compact_Control_Transformers/240x120_VAC_to_24x12_VAC/PH50PG
Jacob
