alexm3g
- Austin, Tx
Greetings,
My retard mind is failing me so any insight would be appreciated.
Recently the electric room in my facility smelled like a burnt transformer. I found a tripped unit located in an MCC and it appeared the smell was coming from within the cabinet. Upon opening the unit, the smell definitely originated from inside and I began troubleshooting. All the fuses were still good, connections tight, and no burnt wires. I pulled the control transformer, did a sniff test and confirmed that this was the culprit. I checked the resistance across the terminals and this is what I found:
Transformer is 0.1KVA
Primary: 480V, 47 Ohms across H1-H4
Secondary: 120V, 6 Ohms across X1-X2
Reading such a short resistance I figured that it was no good. After receiving the new one I measured its resistance and got the same thing :rant: My Ohms law calculations obviously don't match these numbers. So my question is, how can I do a field test/calculation to measure the winding resistance to rule out a bad transformer? Is this possible?
Thanks,
Retard
Thanks,
Retard
