sundowner
- West Wisconsin
Have been noticing several control transformers lately, (installed years ago in existing motor starters) most without a secondary bonding wire from the X2 terminal to ground, the new equipment which comes in all have secondary grounding wires installed from X2 to case. ( 480 Volt pri/ 120 volt sec) Am I thinking of this correctly in that there is a KVA level at which it is required to ground the secondary, or is it anytime there is a XO terminal or a X2 terminal. What I'm looking at is some new HVAC motor starters which land on our 3 phase, 3 wire 480 volt busduct.
My real question is when do I need to ground/bond my secondary of the control xformer--is it only when I see an X0 terminal or X2... confused.
Thanks guys
Thanks guys
