I hope you spelled all that right, cause I just copy/pasted it to a word doc... I WILL use it later I'm sure. Now I know how those charging pads work, but I was actually referring to an article I read about Tesla 'paving the way' (which I have pretty much come to believe) and Edison 'stealing the spotlight'. The article/opinion stated that radio waves could charge a cellphone anytime it wasn't in use; if you were in a populous region (which I tend to avoid). PS I had the same problem with my RM 80, my big brother was the "Jr." so he got the CR 250 I always wanted. Poor me...
That little suzuki did just fine for me though:happyyes:!!!
I'll try to keep this on topic, but since you brought up Tesla.......
In 2006, on the 150th anniversary of Tesla's birth, my voice was heard in Serbia (actually it was 'Serbia and Montengro') on a radio. The transmission was made from my house in Michigan to Tesla's birthplace. The contact was made from my home made antenna in my back yard to the receiving station's antenna in Serbia. There was nothing else in the mix. No satellites, no repeaters, no Internet, nothing but antenna to antenna. I have a post card from the station in Serbia,
YT0TESLA, with the exact date and time it happened on it as proof.
How much power do you think I had to move from Michigan to Serbia in order to get a readable voice contact? Now think about this, I am shooting from a 36 foot piece of wire not as thick as a pencil to a similar target in Serbia. As the energy leaves my antenna, it disperses in a semi-spherical pattern and is diluted in power as it leaves my station. That energy is scattered all over the world, literally. Some of that energy will hit a target less than a pencil thick and 36 feet wide in Serbia. The rest is wasted. Well, unless other people listening enjoyed hearing us talk, that is.
A readable signal in the mode I was using takes about 10 microvolts at the receiving station. A perfect signal, or 'S9', is supposed to be 50 microvolts.
So, in order to be readable I had to put enough energy into my antenna to get 10 microvolts to Serbia without a wired connection.
My radio, an Icom IC-735, puts out 100 watts continuous wave. Since we were using single sideband suppressed carrier, my voice peaks were only at the 40 watt level. My antenna was tuned to match the radio at 50 ohms. That works out to about 45 volts. That 45 volts was detected thousands of miles away in Serbia.
Fortunately, the station in Serbia was a bit like a tick tracer. Neither the tick tracer or the Serbian station used up any of the energy they detected from either the Romex wire or my wire antenna. They just detected it's presence.
To illustrate, one could take a piece of Romex a couple hundred feet long and connect it to a 120 volt power source and have a switch. At the other end a person could hold a tick tracer on it so when the switch was on, the tracer would indicate. Off, it would not. Using Morse Code an understandable message could be sent to the tick tracer and virtually no power would be consumed. This method could be used every day for years and never register on a power meter (watt hour meter).
The same could be done with a DVOM, watching the display change from 0 to 120 volts for the dots and dashes, but SOME power would be used since it does have a measurable impedance of about 100 thousand ohms. Using a DVOM wouldn't use much power, but over many hours of use would register on a power meter.
The same could be done with a light bulb to see when the switch was on or off. But as one would imagine, many hours of use will use up a substantial amount of power.
OK, so we have three different ways to detect voltage on our little telegraph.
What would happen if we put a 10 thousand ohm resistor somewhere in the wire?
Well, the light bulb wouldn't light, that's for sure. But neither the DVOM nor the tick tracer would be affected. Both would indicate that there was 120 volts turning on and off in code.
What about a 200 thousand ohm resistor?
Well, the bulb wouldn't work and the DVOM would read about 60 volts. The tick tracer would indicate just as it always has.
How about a million ohm resistor?
No bulb, no DVOM reading, but the tick tracer would still indicate that there was 120 volts present. Think about it.....how many ohms is insulation??????
THIS is why you need to know what your test equipment is actually indicating!!!
And, I include the light bulb as a piece of test equipment.
Ever heard of a 'test light'?
Yep, I have a 120 volt test light and it has been one of the best pieces of test equipment I have ever owned.
