I have a few question about a 120 volt 20 amp duplex receptacle circuit for a 620' tunnel.The customer is wanting one every 40'.
Question1. When calculating the voltage drop for wire size, can I calculate at the 80% of the 20 amp breaker?
Question2. Do I need to calculate to the last device? Or calculate the voltage drop for the first 300' and then the remainder 300'?
Question3. Do I calculate at 3% or 5%?
I was thinking the 3%, 20 amp at 620'. Given variables requires #1 wire.
Question4. Is this correct?
Given the result, we planned on #1 wire, set a jbox every 40', make a pigtail joint to #10, and whip into a single gang box for the receptacle.
Question5. Is this over kill?
