There is no direct conversion because of different SEER ratings. But for estimating I use 8 amps per ton single phase and 6 amps per ton 3 phase. These numbers will get you close enough up to 5 tons. But for actual wire sizes I wait for name plate data. I sometimes get the HVAC contractor fax me equipment data on their letterhead to make them responsible.
"Search" is your friend here, why the logical of searchs might not always
meet your needs try varibles or like thymes when searching here, and then theres outside on the I-Net.
