al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
If the wood above the flat pan is a 1?" wide framing member, this is a great solution.I would leave the boxes in place and support the fan independently of the box.
One possibility would be to remove the KO that is left and stick a 'Sammy' http://www.itwbuildex.com/sas_wood.shtml on the end of 1/4" threaded rod, run it up through the KO and into the wood above.
Once into the wood enough cut the threaded rod, install a fender washer followed by a nut to tighten up against the box to cover the KO hole and use the remaining threaded rod sticking down to support the fans bracket.
I haven't explored the location, other than to take the snap in the OP, so I don't know, yet, what is above the flat pan, other than it is not lathe.
In my working area, for similar aged RMC / flat pan installations, the flat pan has been positioned by everything from a full sized framing member to 1 x 4 toenailed at an angle.
