I have a 14/3 romex cable running from a three-way switch to another three-way switch and would INSTEAD like to:
a) Replace both three-way switches with standard single-pole switches, each independently controlling their own light fixtures, AND
b) Use the existing 14/3 cable to supply power to the second switch, eliminating the use of the red traveler wire, and connecting the wires formerly attached to the first three-way switch, to the power in the first gang box .
QUESTION: Will there be any difficulty converting down this way when the inspector peruses the work, AND can the red wire simply be capped off at both ends?
Thank you in advance,
Richard Linespike
Richard Linespike
