converting 60 to 50 cycle
Re: converting 60 to 50 cycle
my first question is why would you want to. a lot of stuff out there will work fine on either frequency.
Couldn't you also reduce the rpm speed of the generator motor?
Theoretically YES.
We have acustomer who manufacturers 50Hz equipment. We installed a motor generatro for their application. Standard 3ph 480V 60Hz runs a 220 V 1 phase 50Hz generator.
Would be cheaper to buy equipment designed to run on 50Hz rather than buy expensive motor generators and the like.
