Converting T12 Lamps To T8 lamps
tdaug53
Can I convert a standard 48" 2 lamp T12 Fixture over to the T8 style lamps by changing the ballast to a new electronic style? What would happen if someone just changed the lamps from T12 to T8 and used the old style ballast rated for 2 F40 T12 lamps?
All the T-8 change-overs I've done simply required connecting both wires of each socket together and to its single ballast wire.
