I don't know about the lub..but the torque wrench damaging equipment issue has kind of annoyed me so I shall expound on this issue..I feel when we all have done this for some time the damage incurred with a torque wrench is only to the item being torqued..why do I have to be so specific? Now I have done a little research and ask some of my friends since the last time we were on the torque wrench issue, like calibrating the torque wrench. I ask electricians, industrial mechanics, and some auto mechanics. The mechanics use torque wrench's why more frequently than we do..out of all the people I ask around 20 not one of them have had their torque wrench calibrated in the last year some of them even said they have never had them calibrated. the majority of them did say they turn them to lowest setting and keep them in the cases..so now some of the most common wrench sizes are 1/4" drive is 20 to 200 inch lbs, in 1lb increments. 3/8" drive are 40-200 inch lbs, in 1 lb increments, 3/8 inch drive 10-150ft lbs, in 5 lb increments, 1/2" drive 25-250ft lbs in 1lb increment..now you can get specialty wrench's and the increment ranges run from .2lbs to 5lbs and even in 3/4" and 1" drives..the accuracy rate of torque wrench's ranges from 3% to 6%..so 200 inch lbs of torque is only 16.6 ft lbs and that is on low side so to use a ft lbs torque wrench on an inch lb torque item could cause damage to the item being torqued. the information on torque wrench came from researching various wrench on the Internet and reading their specifications..
