Good Morning,
Under the NEC are pull wires required to be hardwired directly to the conveyor safety circuit.
The installation we have here has each pull wire going to the PLC and the logic stops the conveyor.
In the past under IEC the safety circuit has been a requirement.
Also is there an NEC article focused on Conveyors. I would assume there would be rules like the pull wire must activate in both directions, must activate it the wire is cut etc.
Thanks in advance.
Thanks in advance.
