I currently have two saws that each run a set of waste conveyors when the saws are turned on. The conveyors are mostly outside. They would now like saw A to be able to turn on the conveyors of Saw B when saw A starts up along with Saw A's conveyors. They still want saw B to turn on its conveyors when only saw B is running. It makes sense when you see it and how the conveyors sort waste by length.
Could I get a little direction on how to do it? Can I make it NEC compliant? Are there contactors with double coils? Could you use something like a reversing contactor but not make it reverse?
Any insight would be greatly appreciated. All motors are 3 phase, 480 volt.
Thank You
Thank You
