Re: cooktop
An open heating element would measure infinity on the Ohmmeter. Possibly the heating element could short to the metal sheath around it. It is quite possible though that grease and crud have leaked into one of the control units and created a partial short.
The resistance would change considerably with temperature but not as drastically as a light bulb which operates at a much higher temperature. Resistance is not so important here as continuity.
In short, you need to check continuity between the disconnected terminals and from each terminal to the metal sheath.
But first take a good look at each of the control units, and also check for broken wires and frayed insulation.
Sounds like a new cooktop is in order.
[ February 02, 2005, 11:32 PM: Message edited by: rattus ]
