timm333
- Minneapolis, MN
- Electrical Design Engineer
I have a question about the protective device coordination. There should be certain coordination time interval (CTI) between the TCC's: for example 0.12 sec between relay and breaker, 0.25 sec between relay and relay, 0.3 sec between fuse and relay, and so on.
But usually in the coordination examples, these intervals are not used, they only say that the upstream TCC should be to the right and above the downstream TCC. Is it normal to not strictly use the coordination time intervals between the TCC's? Thanks
