BigJohnny
New member
- United States
I have recently seen where 0n a 400 Amp 120/208V 3 ph meter main combo from Sylvainia when a lost leg during construction temp power use caused bolts that connected the CU & AL buss together burned. As a quick fix a EC re bolted and put Nolux on CU & AL buss. This is a short term solution long term problem. There is another 400 amp unit next t it and when opened it to has CU & AL buss but has plastic spacers between. I have never seen this and why would this be done at the factory or is this why Sylvainia is no longer making these units. I just don't like it and think the unit should be changed. What do you think?
