250.52(A)(5) Rod and Pipe Electrodes.
Rod and pipe electrodes shall not be less than 2.44 m (8 ft) in length and shall consist of the following materials.
(a)Grounding electrodes of pipe or conduit shall not be smaller than metric designator 21 (trade size 3∕ 4) and, where of steel, shall have the outer surface galvanized or otherwise metal-coated for corrosion protection.
(b)Rod-type grounding electrodes of stainless steel and copper or zinc coated steel shall be at least 15.87 mm (5∕ 8 in.) in diameter, unless listed.
Saw it on the search engine.Where does it say that?
Were you searching a specific code cycle of the NEC?Saw it on the search engine.
No, I just searched what size ground rod do you need in California.Were you searching a specific code cycle of the NEC?
Good evidence that you shouldn't blindly trust search engines.No, I just searched what size ground rod do you need in California.
That's also a low voltage article
That link is from 1983 Cal/OSHA - Title 8 regulations, and for historical reference only.
That's not exactly true. CA doesn't delete anything from the NEC in it's adoption process, but it adds plenty. Most of what CA adds is OSHPD related, and there is California, Article 89.California adopts the NEC without amendments
Thanks for that info. I believe local jurisdictions may also make changes.That's not exactly true.
I wouldn't say 'plenty', aside from article 89. There are a total of 2 modifications in all of chapter 3, for example. There are none to such key articles as 225, 230, 240 and 250.That's not exactly true. CA doesn't delete anything from the NEC in it's adoption process, but it adds plenty. Most of what CA adds is OSHPD related, and there is California, Article 89.
Sure, "plenty" is a subjective term, and (aside from article 89) most of the CA additions are relatively obscure. Those additions mostly show up in the later articles. Collectively there are about 100 additional pages in the 2022 CA Electrical Code compared to the 2020 NEC that it was based on. That's why I used that qualifier in response to "California adopts the NEC without amendments".I wouldn't say 'plenty', aside from article 89.
Sure, "plenty" is a subjective term, and (aside from article 89) most of the CA additions are relatively obscure. Those additions mostly show up in the later articles. Collectively there are about 100 additional pages in the 2022 CA Electrical Code compared to the 2020 NEC that it was based on. ...
I'll take that sandwich.Well you got me curious how that could really be because I would bet a sandwich there are less than 2 pages worth of substantive changes to actual requirements for electrical installations. And my conclusion is that it's mostly font size or some other formatting difference. Article 89 is 27 pages, the matrix adoption tables are 3-5 pages per chapter. That doesn't account for the difference but the start page of each article in the CEC somehow keeps creeping higher than the NEC in Articles that have no ammendments.
