Bama_Electrical
- Alabama
- Electrician
I have a house that I am close to wrapping up the rough-in and I am waiting on the plumbers to wrap up their rough-in. Part of the hold up is all copper water lines in the attic. I know I need to bond it, but have a question on the sizing. #4 good? (NEC 250.66 - largest conductor is 3/0 copper, but not sure what the POCO is bringing to the can) House is a 400/320 AMP service. Going to bond it and jump over to the gas line (AHJ requires gas line bonding) at the tankless water heater. Planning to use #4 for bonding, if ok, but will it need to be bonded in both service disconnects or is 1 sufficient? There is also 2 tankless water heater units and pretty sure the AHJ will require both to be bonded, so will probably be doing this twice.
