K8MHZ
- Electrician
I need to repair a broken grounding electrode connection for a radio tower. What I am up against is 6 inch wide copper strap used as a grounding electrode conductor that needs to be attached to a 5/8 inch grounding electrode. The original installer used solder to attach the strap to a bare stranded copper wire and then Cad welded the wire to the electrode. He left it exposed and it got ran over by a vehicle and the connection broke. The inspector pointed out that the solder only connection was an NEC violation. I also pointed out that the connection was left unprotected. I need to make this repair soon and since it will be inspected it has to be code compliant.
The inspector suggested using ground clamps for a mechanical connection with solder as an addition. I would rather use something listed for this type of connection as clamps do not appear to be listed for use with strap. The inspector is being very lax and his main concern is safety and functionality. My requirements for this job have exceeded his expectations. Our company did not do the original installation. The company that did never pulled an electrical permit and I was called in to work with the inspector and pull and close out a legal permit after the fact, so to speak.
What is being protected is a 200 foot tall rotating amateur radio tower. If I did the design I would have used a different method, but it's too late for that.
Any help would be appreciated. I did put in a call to Theka (they design and install cell towers) and am waiting for a call back. The owner lives near me but is a pretty busy guy so I don't know when he will call me back.
Thanks
Thanks
