I know the code requires HP ratings for the plug and body used as a disconnect for a motor.
However, if you are connecting a machine, like a mill, that has a power switch built in, can you consider the built in switch as the disconnecting means, and just rate the plug and connector body for the load (non HP)? I see machines connected like this all the time, and it seems like none of the connector bodies are HP rated...
Thanks,
Bryan
Thanks,
Bryan
