bphgravity
- Florida
I have a water equipment installation. The equipment includes a well pump, house pump, and water softner. The pumps are supplied through pressures switches.
Two, 250V - 20A rceptacles are installed approx. 12' from the equipment pad. From the pressure switch for the well pump is an orange extension cord hard-wired to the switch, exposed for about 3', run through a sinbgle lenth of Sch 80 PVC, exposed on the other end for another 2' and plugged-in. The other pressure switched is fed with what appears to be a dryer or range cord. Again this is hard-wired to the switch and plugged into the receptacle around 8' away. Both cord-caps where field installed.
Anyone comments on this one?
