Using 2002 NEC
Having an issue with natural gas-fueled Forced Air Units (FAU's) in the attic of trac homes.
AHJ sites article 422.12 and 422.16 and says I have to use hard wire with a fuseable disconnect to the unit.
422.12 just says it has to be an individual branch circuit, which it is. Not even a multi-wire, just a plain, simple 12/2 home run back to the panel. (yeah, I know it is just supplying a squirrel cage and a small current draw for the computer board and ignitor, and I could probably use 14/2 instead, but I have learned to pick my battles so I use the 12/2.)
422.16 supports my position, IMO. I see nothing that states I must use hard wiring. The disconnect is the cord to the single (not duplex!) 20 amp. receptacle I install for the unit.
Ideas? thoughts? suggestions? threats? snide remarks?
