- Logan, Utah
According to 410.30(C)(1) to be able to cord connect an electric discharge luminarie you must comply with both (1) and (2) of this section.
(1) being that the luminarie is located directly below the outlet or busway.
And
(2) requiring
a. the cord is visible for its entire length outside the luminarie
b. the cord is not subject to strain or physical damage
c. the cord is terminated in a grounding-type attachment plug cap or busway plug, or is part of a listed assembly incorporating a manufactured wiring system connector in accordance with 604.6(C), or has a luminaire assembly with a strain relief and canopy.
So here is the question I have:
I have a building that has 400 watt metal halide fixtures that are independantly hung from the outlet box. These fixtures come with an 8 foot cord without a cord cap. The cord are connected to a 4 square box with a cord connecter and hard wired. Is there any exceptions to 410.30 that I am missing that would allow this installation? As far as I can see you need to use a "grounding-type attachment plug cap" on the end of the cord.
Any insight would be greatly appreciated.
Chris
And
(2) requiring
Chris
