ronmath
- Burnsville, MN
Does Article 400 allow the use of SO or other approved cord to feed retail gondola receptacles from above? Does there have to be a twist lock plug between the receptacle and cord drop or can the cord run right into the J-box to be hardwired within the gondola? Also as a separate question, would it be allowed if fed from a busway under 368.56 (B)? I understand if used, proper support and strain relief would be required.
Thanks,
Thanks,
