Cord or Cable?
Not being an engineer ...
A recent grad (with accredited degree in hand), asked me a simple question.
What is the difference between a cord and a cable. (Table 400.4)
I turned to section 100 ... No definition.
The best answer I heard was: A cable is permenant and a cord is not.
Any suggestions?
MarkN
I'll take a shot. I would say that mostly it's the outer covering. Cord also has stranded wire for flexibility where as cable has solid wire in it.
With no authority at all, I've see the definitions that 'wire' is a single conductor and 'cable' is multiple conductors in one assembly or jacket. 'Cord' is a cable that's designed to be remain flexible. I'll also fall back on the m-w.com definition: "a long slender flexible material usually consisting of several strands (as of thread or yarn) woven or twisted together "
How about a cord is a flexible cable assembly dedicated for use with a fitting(plug or receptacle or both) on the ends while a cable is normally more stiff and is terminated on terminals of sorts with or without lugs.:-?:-?
dick
