Cord & plug connected Outdoor Receptacle
mgookin
Fort Myers, FL
I've been asked to adapt our timer to work in a cord & plug connected version with an outdoor receptacle. The easiest applications to visualize are powering cord & plug connected landscape transformers, holiday decorations, etc.
The user will need to be able to mount our device, plug it in, and plug their device into our device without needing an electrician.
Our timer presently is only in twist-lock or wire-in receptacle form.
I can take any wet location box and stub an LB off it and mount our wire-in unit on the LB. That's not a problem. It's ok that whatever we come with that they'll need to mount it to a wall or pedestal.
Or something bigger than the above if necessary.
Question: How could I power this box with a cord & plug so that any trainee kid working for a landscape company can mount it to a wall, plug it in, and plug in his landscape lighting transformer?
I'm thinking I can just make a whip out of SOOW. How long would that last?
Any better ideas?
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
I think you would find it easiest to work your GPS timer into a cord and receptacle arrangement like this:
I suspect that taking advantage of UL 62 will be to your advantage. There is a great thead on the subject you can read by clicking here.
mgookin
Fort Myers, FL
Thanks Al.
That would be fine for Christmas lights because of the temporary nature but today's customer is a national landscape lighting supply company. I went to a big box and picked up some outdoor receptacle parts & some SOOW. Took about 5 minutes to put it together. I'll send it to them and see how they like it.
We probably will do something like the picture you showed but would never intend it to be a permanent installation.
Thanks again.
