Cord size for portable equipment
Silveradosparky
New member
Calif.
Hello, we have several portable pumps (20 hp, 460 volt, 27FLA, with VFD on cart) that will be plugged into 60 amp receptacles. What is the proper cord sizing and where do I find it in the NEC. Thanks,
VFD max input amps x 1.25, adjusted for length because of possible voltage drop, rounded to the nearest legal limit on portable cord, but only if the CB/Fused Disconnect feeding it is sized that way. If the CB/FD is 60A, you use 60A cord..
So as an example, looking at an A-B 20HP 480V VFD suitable for a 27A FLC motor, no more than 3% voltage drop;
Max. Input Amps is 24.8A, x 1.25 = 31A, you are looking at #8 SO cord, assuming less than an 80ft run and a CB rated 35 or 40A max.
But if the CB / FD feeding that receptacle is 60A, the cord must be rated for 60A, so that would be #4 SO under the same circumstances.
