This is a similar question to the computer room article 645 code question. If you have a raised floor room, but you don't fall under all the gotta have's of NEC 645, can you run non-DP power cables from equipment through a 4" hole in the floor to an outlet box mounted on the floor (about 2' below the top of the floor)? This floor has no air being pumped into it, so its not an environmental air space. I see this just as a concealed space, that is actually easy to reveal since the floor tiles lift out.
Our inspector seems to want flush floor boxes and I don't know why.
