Hey everyone.
I was up on a roof today looking at a 4160/480v 3 wire corner grounded delta or grounded B delta system. The cables were in open air and missing the sheath in many places but thats not why I am here. This is the first time I have had any experience with the system. My question is more theoretical than anything else. So lets assume phase B is the grounded phase. I under stand how it works, 480 phase to phase and phase to ground except B which is zero phase to ground. so my questions are:
1. If I came into contact accidentally with the grounded phase B, nothing would happen correct? Since I would be grounded and there is zero potential between myself and the B phase?
2. Also would the same be true for an ungrounded system? If you "fault" an ungrounded system it more or less becomes a corner grounded delta. What is the potential to ground on an ungrounded system?
I only ask because if I am right, then wouldnt corner grounded delta and ungrounded systems be much safer systems? Are there hazards that arise which are not obvious at first?
That's all, thanks!
That's all, thanks!
