I have a job that has a corner ground delta system . It is servicing a multiple meter set up. I attempted to check ground to neutral continuity at one of the panels and it did not exist. I checked main bond jumper and it was installed. Is this lack of continuity a function of the corner grounded delta system, or do I need to look deeper for a broken connection.
