Hello,
I am working on a motor install for a corner grounded (480 grounded b phase system).
Motor - 50 HP Leeson wired for 480. Motor shaft spins freely by hand. Motor passed all the multimeter test prior to wiring.
breaker - 350 amp siemens (existing is the only reason its being used) with all three phases turned to 1 (8 is the highest setting).
When we tried to start it it made a buzz and then popped a a slow blow fuse in the disconnect on the grounded b phase. The 350 amp breaker also tripped (all three phases turned to one).
My question is could this problem all be related to the breaker phase settings being turned to one?
