hardworker
Corner Grounded Delta that has 240vt and 240vt and 0vt on the three phases. Is there a transformer to convert this to 208vt three phase?
Don’t let the corner ground delta intimidate you.Corner Grounded Delta that has 240vt and 240vt and 0vt on the three phases. Is there a transformer to convert this to 208vt three phase?
The phases are 240 and 240 and zero.Don’t let the corner ground delta intimidate you.
with a delta you always check voltages L-L, because that’s what matters. So you have 240,240,240
with Y you can check voltages to a common point and across the Y
How did you measure these voltages?The phases are 240 and 240 and zero.
You are checking voltage to the grounded phase? Why do you expect it to be anything other than 0?The phases are 240 and 240 and zero.
A to B = 240
B to C = 240
A to C = 240
(C being the grounded phase for this example)
C to C should = 0
The need to would be rare, but why do you want to covert to 208v? I would think, in most cases, it would be cheaper to just replace the 240 delta transformer.Corner Grounded Delta that has 240vt and 240vt and 0vt on the three phases. Is there a transformer to convert this to 208vt three phase?
240,240 and 0 could also indicate a blown fuse…The phases are 240 and 240 and zero.
Those are the Line - Ground voltages. As others have pointed out the Line - Line voltages are all 240V.The phases are 240 and 240 and zero.
Depends on the kVA of the existing 240 equipment and how that might need to be converted to 208. Might be more economical to just order 240V equipment and use whats there.I would think, in most cases, it would be cheaper to just replace the 240 delta transformer.
Right. You connect the ground to neutral on the 208Y/120V secondary.Don’t let the corner ground delta intimidate you.
Areas of concern converting a corner ground to a wye include:Might be more economical to just order 240V equipment and use whats there.
Thanks for the link. I am checking with them. I think they have what I need.
That's probably the most common usage for a 240D-to-208Y transformerCorner Grounded Delta that has 240vt and 240vt and 0vt on the three phases. Is there a transformer to convert this to 208vt three phase?
