websparky
- Cleveland, Ohio
I have a new service installation for a pump station. The part I am not sure of is the 480V wye to 208V delta transformer. The secondary will only have one 230V 3 phase pump and nothing else. The 480V side will be grounded in the usual manner. The 230V delta side has me unsure of the code requirements for grounding the system. I think I will need to corner-ground the delta in order to have a ground-fault path for the secondary side. Right? Is there another code compliant choice?
TIA
TIA
