Electron_Sam78
- Palm Bay, FL
I've got a separate structure with a 1ph corner grounded delta 480V that is being stepped down to 240/120V (center tapped/grounded secondary). I'm replacing the existing panel and noticed some code deficiencies that I'm going to correct when I replace it. For one thing the corner grounded system is entering the building and the grounded phase is fused inside the disconnect. Another is that the grounded phase of the corner grounded delta is not connected to a grounding electrode or any equipment grounding connections. The CB panel fed by the transformer secondary (240/120V) has a grounding electrode where the secondary center tap (neutral) is connected but as stated the corner grounded delta supply is not connected to it.
My proposed fix is:
1). Get a new disconnect with a neutral bar and run the incoming corner grounded phase into the neutral bar. I will also connect the neutral bar to the metal enclosure of the disconnect and a grounding electrode (no equipment ground was run with the supply).
2).Connect the neutral bar in the secondary fed panel to the same grounding elecrode the supply system is connected to as well as the metal panel enclosure.
3). Make sure all metal equipment frames and conduits are bonded together and grounded
I believe this corrective action is right according to code (2008) but let me know if I need to change something
My proposed fix is:
