It is my understanding that a corner grounded delta system if for ground fault detection. Is this the only reason for corner grounding a system? How does a corner gounded system work for ground fault detection and OCPD's?
Are all of the line-line voltage in a corner grounded system still the same? I'm assuming that the grounded phase to ground voltage is zero and the other two phase to ground voltages are normal phase go ground readings?
