Re: Corner Grounded Delta
The question of whether it would be safe to touch the grounded conductor raises some concern for me. I believe this may be true if and only if the person is bonded to the same ground reference as the conductor. If I am not somehow bonded to the same potential as the grounded conductor, it stands to reason that it is NOT safe for me to touch it because there is a potential for a voltage difference between myself and the grounded conductor.
With that said, it is never safe to assume you're safe. As Charlie pointed out, even a couple feet can make a difference. (pun intended)
If I'm wrong, I look forward to an education from you more seasoned, knowledgeable folks.
Bob
