sparkyclark
New member
I'm trying to find some more info on corner grounded delta systems, the company I work for wants to install one and I told them that it's not a very safe system can anyone help?
I think you are required to ground one leg. Otherwise you may get transient voltages. It the same as grounding the center of a winding on a delta or the center of a Y transformer. When you read voltage with a meter to the grounded leg it will be zero. But between any of the others it will be whatever the applied voltage is.sparkyclark said:I'm trying to find some more info on corner grounded delta systems, the company I work for wants to install one and I told them that it's not a very safe system can anyone help?
