jxofaltrds
Retired ESI
- Mike P. Columbus Ohio
- Creator
Example:
I install a 20-amp circuit for my whirlpool.
It is a Jacuzzi brand.
From Jacuzzi:
"Depending on the model of the whirlpool bath, the installation/operation manual specifies which units must be 15 amp versus 20 amp GFCI protected. Since the model number or name of the unit was not listed in this email, you'll need to look at the specifications sheet to determine which is needed for your installation. It is clearly stated at the bottom of the page on each spec sheet. If we require a 15 amp set up, we certainly do not want the unit installed on a 20 amp breaker and yes, putting a 15 amp required unit on a 20 amp service can cause issues with the unit."
If this is protected (the circuit) with a 20-amp breaker, is this a code violation?
Mike P.
From Jacuzzi:
Mike P.
