Steve McKinney
Fellas, I have doing this a while, but I have never seen this. Customer complains that every now and then about half of his house goes electrically dead. OK, no big deal.........happens all the time. Probably a bad line connection at the meter or panel. He has had success restoring power by pulling out the main plug in cartridge fuse holder and slamming it back in. OK, that is where it is, right? Trouble is, when it goes dead, sure enough, one side of the line coming into the panel from the meter base is 0 volts in reference to ground. Other side is ok. And of course, line to line is 0 volts. Then we perform the hi-tech slam and the voltage magically appears. 120 to ground and 240 line to line.
I might add that it is a very old install as you can imagine. I expect I will be soon changing out the service, but I am having a time "noodling" this out!
The meter can and the panel are connected with about 7 foot of old SE cable.
Any of you experienced such a head scratcher?
Thnx in advance.
Steve McKinney
"When you're green you grow, when you're ripe, you rot!
Thnx in advance.
Steve McKinney
