mbrooke
Batteries Included
- United States
- Technician
This is from an EE book and I am having trouble understanding what I am seeing. It seems as though DC corona varies in magnitude by polarity? Or is something else at work?
Discharge between two identical electrodes will be identical for both polarities of DC, while AC may be different because the current passes though zero repeatedly.
If the two electrodes are not identical there can be asymmetries. Air will be ionized where the field gradient is highest, such as thenear sharp points. And the results can be different depending on whether those ions are positive or negative.
add in for where the light comes from from added query.
To dark with the camera set to capture the brighter streamers a 10s of kV/ cm field strength, so the cathode glow is not seen in the photos.
The light is a function of electrons and ions being torn apart and re-combining - in a cloud at the cathode, bright streamers in the electron flow path at the anode. As the electrons in the; molecules change state, they give off a color consistent with the distance they jump (very colloquial description) - thus air is blue because of the size of the air molecules, neon is yellow orange, red for other gases, neon tube makers take advantage of the different sizes of argon, neon, helium, etc. to produce different color signs.
If one put dc on a neon sign, all the color would be at one end of the tube, the other basically dark because of low current and the streamers would not be bright enough to be seen. Gets more complicated on what is seen when different tests are run at different gas pressure, etc., suffice it to say at low pressures and current (few electrons flowing) the cathode glow is most visible, at high pressures (e.g 15 psi) it is the streamers that are most visible.
The photo below is a common neon glow tube on dc. The LH terminal is + (note cathode ring on the diode). This is at only a few mA so the glow is seen but streamers are invisible. The far left photo is in normal room light, the middle photo is with darker room and auto camera shutter. If one looks VERY closely, you can see small streamers from the tip of the anode.
Hope this helps vs. confuse farther?
PS: fluorescent tube is full plasma arc thru the mercury vapor, ac or dc. Light is from UV from the mercury arc hitting the phosphors, not from streamers or cathode glow as described here.
The photons are emitted as electrons move to a lower energy state. They are in a higher energy state in the first place because of the energy released in the recombination process and other collisions.I thought the light was caused by electrons moving from a higher to a lower orbit in the atom being ionized. As it drops to a lower orbit a photon is emitted. Inversely if a photon hits an atom with enough energy, it moves an electron to a higher orbit or even releases an electron from the valence orbit if it is greater than the work function value for that atom.
