Mucka1
New member
- Qld , Australia
Hi,
I have just purchased from the USA a greenlee EK425L with CJD30 jaws, battery operated crimper, to be used for joining 2.5mm and 2.8mm galvanized Fencing wire, using double barrel aluminum gritted crimping sleeves.
I need 2 sets of W style dies to fit the crimp size.
The first is 6 mm cavity when die is closed and the second is 9 mm when closed, these measurements are taken from the jaws of a manual crimper that when completely closed is the correct size tool.
The numbering on the manuel tool has no relationship to any die sizes that I can see, and these dies or battery operated crimpers don't seem to be available here in Australia.
As I have no experience with die charts, I was wondering if there was anybody that might be using or have knowledge of a similar size die or very close to it and be able to help me out with the part number so I can purchase it.
Thank you.
Thank you.
