300.6(A)
Ferrous Metal Equipment Ferrous metal raceways, cable trays, cablebus, auxiliary gutters, cable armor, boxes, cable sheathing, cabinets, metal elbows, couplings, nipples, fittings and support hardware shall be suitably protected against corrosion inside and outside
(except threads at joints) by a coating of approved corrosion-resistant material. Where corrosion protection is necessary and the conduit is threaded in the field, the threads shall be coated with an approved electrically conductive , corrosion resistant material.
Lightweight for thread dope –
TOP > EXPLOSION-PROOF CERTIFIED EQUIPMENT > FITTINGS > THREAD LUBRICANTS > 78227461415
Heavy-duty for thread dope-
From the manufacturer:
Kopr-Shield compound is a unique homogenized blend of pure, polished colloidal copper, rust and corrosion inhibitors that simultaneously protects, lubricates and
enhances the conductivity of the mating surfaces to which it is applied. Extremely adhesive, Kopr Shield compound flows smoothly into uneven contours and voids, making application easy, protection and lubrication complete and positive. A stable compound, it
will not settle-out, thin, thicken, harden or dry out under the most severe environmental conditions.
Kopr-Shield compound has excellent temperature characteristics - brushed on at -50F to 250F (other compounds either turn solid or run like water at these extremes). Even at 1800F Kopr-Shield remains intact for short terms.
Kopr-shield Compound may be used to advantage in all electrical installations. When the environment is hostile to good electrical and mechanical connections.
When working pipeline projects there spec book (E400) tries to tie into the code as much as engineering tech writers can. Per their call out for conduits-
3.3.3
All conduit shall be square cut, reamed inside, and threaded to connect to couplings and fittings. The Contractor shall use thread compound suitable to arctic environment, to obtain a tight joint. The thread compound shall be listed as electrically conductive and shall not affect grounding continuity of the electrical system. Refer to NEC Article 300-(A).
My commentary:
Perhaps we work in different environments, and interpret the verbage from the NEC differently, but this is the standard I am used to. I believe that between the manufacturers representatives, and others who sit on code making panels, that the wording is quite clearly intended to steer a person into just a few options. The above are some options which exceed the callouts for the work that I use it for, but is the standard for the work in our area.
